Just wondering what the best practice is for putting text on top of colour in a graphic item. I made a box with orange in it in illustrator, added white text on top of it. dropped it into FW, made the settings png, millions with no AA. The text just looks a little blurry around the edges, but is way better than it look saving it as a jpg. Im wondering if i am doing this the wrong way, or that the contrast between orange and white is just not there. I thought i would get sharp text. Any thoughts? Sorry there is not link at the moment.
A
Any reason why you don’t add your text in FW on top of the Illustrator graphic.
Then you can play with the AA settings until you are happy.
Cheers David. I will do.
I was hoping to try some web fonts with this. Do you know if typekit works in the same way as google webfonts?
They all work in a similar way fontface is another.
Just realised that Typekit is a subscription service - why pay when you can do it for free!
Because i wanto to use ff meta. Imho this is the best small text font that exists, followed by dax. I know what you mean tho. Cheers again
If you own it and are allowed to use it on the web (caveat) then http://www.fontsquirrel.com/fontface/generator
Mmmm (insert one raised eyebrow). You might be on to something. Us weegies know a thing or two.m
Paul4
(Paul)
May 2, 2012, 9:25am
9
My Caxton Action should help you get FontSquirrel fonts working in a Freeway generated site.
http://www.actionsworld.com/Actions/Caxton
