[Pro] Bullet Lists Without Indents
Can you make bullet lists without indents?
And. how can I make a short 2-column bullet list in a flow of text?
Thanks.
Bob
This old thread dealt with this: http://www.freewaytalk.net/thread/view/29329#m_29332
There may be something more recent. Try searching for list style, or styling bullet list.
Thanks, I’ll poke around.
Bob
Easy enough. Head over to your CSS palette, click on the COG in the top right, and choose ‘new style’. Then in the Name field call it ‘nobullets’ and then underneath that in the ‘Paragraph’ area choose ‘List’ from the little drop-down and then from the larger drop-down choose ‘unindented’ and then click OK. Then select the items in the list you want to apply the un-indenting to and apply that style to it.
Thanks, Dan.
Any easy way to make bullet columns within text flow. Say, after a paragraph there’s a list of six bulleted items, three in a left column, three in a right column, then more paragraphs after that.
Bob
I’m not sure it’s so easy, but it’s do-able. Here are a few methods to accomplish it but I haven’t tested these or anything.
It’s not essential. We come from a print background and my designer works in InDesign and is used to print typography.
I’ll have to convince her to make a slight change!
But, I’ll check out the link, too.
Thanks.
Bob
