Is there any way to get a calendar like this within freeway or somehow to create one?
http://www.bdgfx.com/haviland/events/
Sure if you want to add jQuery into the mix - http://arshaw.com/fullcalendar/
any way without jquery, just html based? or smthing similar
You could embed a Google Calendar in your FW page - an iFrame would do it.
that’s what i was thinking,thanks
Dave, where does the jQuery code go for something like this?
Generally references to add code libraries like jQuery go in the before slot of Page>Html Markup but you can also use an action like Walter’s Protaculous 2 that has an ‘Additional Javascript Libraries’ section.
