I am sure I have done this before but id like to know if I can use extended to fix the height of a table cell and how.
many thanks Adam
many thanks Adam
Click within the middle of the cell so you see the fat gray selection
rectangle over its border. Click on the left-most tab of the inspector
and click the Extend button in that pane. In the resulting dialog,
click New, and enter the following Name / Value pair:
style height:200px
Be sure to put only style in the name field and only height:dimension
in the value field.
Obviously, change this value to something more like what you want.
As usual thanks Walter Ill give that a go.
regards
Adam
