Hi,
Does anyone know if I can GROUP 2 items together, then apply the TRANSITION Action to them one time, instead of the transition action to the 2 items individually? I am trying to reduce the number of transition item actions on a page.
I have icons with captions underneath, each with transition effect. Want to reduce the amount on a page.
Barry
Try using the Image Caption action - apply it to the image and you dont require a separate caption
As much as the Image Caption Action seems good, I see it can get a little involved if you want the caption text to be a certain font, color, size, etc.
So I actually took my 2 graphic boxes (1 with image, the other is the caption with the text beneath it).
I selected both and hit GROUP, I then applied the transition to the grouped item and it worked. It saved myself 20 transitions running!!!
cool!
Can we have look at it?
(very curious how it looks and how you managed it
/ Omar
::: Communication to improve civilisation :::
s_ip
Hey Omar…
You can check it out here.
There is no rollovers over the icons yet but the icon and text beneath were done easily as described above.
http://hoffkids.com/FWtest/home.html
