[Pro] Can this be done in FW? if yes How??
I am working on a site where I want to use this type of carousel with pop out windows above the page and some kind of controls on the pop up window; close, back, forward and numbering.
The first example is this and is my favored, the carousel moving continuously and also controlled by mouse: adriangrezda.com . Clicking on a thumbnail a window opens above the page in the center.
The next example is simpler but has the same effect. It is controlled by the navigational arrows and clicking on the thumbnails a window opens, clicking on the image it closes : http://www.kelakongoli.com/
I have tried to create something similar, but is far from the original. I can’t create pop out windows, I have to make separate pages with links. See this: http://is.gd/esyoy0. Is there a way to create the same thing in FW?? I would appreciate any hint, help or instructions.
Thank you.
Dan Demetriad
This example uses Carousel with mixed content including a Showcase. http://www.deltadesign.co/fw_examples/fwactions/slide-show-hide.html
I am sure you can use ScriptyLightbox in there as well
Thanks David. All great in your samples, but I still do not know how to get to image popping or to use Showcase. Can’t find anywhere instructions for it, just entries from people having problems using it. Is there any way that your file can be downloaded so I can understand how was made??
Thanks again
Dan
Sorry Dan - HD failure on my iMac means that I cannot give you a file to play with until I get it replaced.
But this example is a straightforward Carousel construction with a Showcase item in one of the Carousel Panes.
I am sure that you could also use ScriptyLightbox on the individual graphics you have in your Carousel panes.
