Cant get two transparent items to create a rollover one at 30% the other at 60% is this a known issue or is there a workaround?
Tony
Tony
I just used my brain… problem solved thanks if you’re about to send a reply.
As long as you didn’t stick it through your screen! ![]()
CSS swap backgroundimage?
CSS change backgroundcolor (rgba)?
