The Carosel on the linked to example page above contains 3 images but these will no longer work correctly. ie the carosel only display one image repeatedly.
I’ve tried:
• relinking the ‘carosel panes’ to ‘carosel 2’
• copied and pasted from an older vertion
This is only a problem on this particualr page. All other pages with the Carosel 2 action are fine.
Can any one see a problem on this particular page preventing the action form working correctly?
More likely than not, the Action has gotten confused during the page publishing process. Try this:
On the problem page, select each element of the page that has a Carousel Action applied to it, and remove the Action from that item.
Publish (you need not upload) once.
Go back through the page, and re-apply and re-configure the Actions as they were.
Publish again.
Hopefully this will sort it out for you.
On Apr 9, 2018, at 4:09 AM, Tony email@hidden wrote:
Good morning All
Can anyone solve the follwing problem;
I’ve tried:
