Moving this to a new thread, the other one was way too long!
I’ve just updated Carousel to remove padding and margin (along with border) from the outer container it creates for the effect. This should completely avoid the issue Tobias noted, and increase the number of layouts that are compatible with Carousel.
No matter, I appreciate your help with this regardless when you are able to look at it.
It was just important for me to get your confirmation that you are aware about the bug (and the confirmation that it is a bug and not an intended behaviour) and that it’s on your to-do list.
tobiaseichner
