Hi everyone
Is there a hack available to use the current carousel action as would love to use this inline.
Hi everyone
Works inline for me. What have you tried that doesn’t work?
The carousel element itself can only be sized in pixels, but the
container you place it in can be sized in any way you like. There is
no way to make a carousel element work with percentage sized elements,
because it has to move a defined distance in pixels for each jump.
On Aug 27, 2011, at 12:42 PM, Bonsai Bart wrote:
Hi everyone
would love to use this inline.Cheers
The carousel element itself can only be sized in pixels…
Hmm, I didn’t read the “100%” subject heading that way, but you’re probably right.
Hi Everyone
Another day and a clearer head, after experimenting what I have found is that if you apply the carousel action the auto glide has no value (blank field) and works fine. But if you set the auto glide feature to have a value (playing around) and then set it back to zero after you publish the action it has a mind of it’s own. In order to correct remove action and then reapply. Sorted.
Thanks for the responses.
