On 13 Sep 2016, 1:30 pm, The Big Erns wrote:
I tried this: Google…
https://www.google.com/search?rls=en&q=responsive+carousel&ie=UTF-8&oe=UTF-8
This turns up several I think very promising ideas on the first page. Unless the search terms must be
responsive + carousel + only for Freeway
then follows much disappointment.
So the best answer I think is to consider how such things are done and then if you need, how to work that back into Freeway.
Carousels in general use a combination of javascript and css styles. The scripts and styles for Freeway’s Carousel just don’t allow for any flexibility. So I took those google results and randomly picked one and implemented it.
http://cssway.thebigerns.com/workbench/marquee-carousel/
And you can see the OWL Carousel acting responsively. Took a little poking and prodding, but it works as advertised, has plenty of options. The biggest drawback is how it fails when javascript is disabled, so I probably wouldn’t use it provided I could be persuaded to put that type of content in my page in the first place.
I also added the Marquee element as a simpler alternative-- and to make a bunch of other points that I think that I will forgo as I now realize where I am posting this and just how done I am preaching to this audience. I’m sure that people will get the idea without my needing to explain it all just fine.
Hello Ernie,
Many thanks yet again.
I take your point about googling for solutions but I guess I was just checking with the community of experts here as to any options or work rounds or whatever within Freeway itself before I searched for an external script. Now that seems to be the way forward. I’ve had a look at a few options and the Owl one seems feasible.
I really appreciate your outline regarding the Marquee element. I guess it may be jettisoned like many other scripts and actions and ways of working as website development evolves further.
I guess I was just wondering really what everyone else uses in such circumstances where they want a responsive carousel.
You have given me a direction of travel on this and I do thank you for your unselfish help and support.
Tim, thanks for that link.
I’ve had a look at this also and can see this as being another viable option. I shall see how I get on with that but I reckon it could be a fresh challenge to build it in Freeway. If I can then it will be very useful.
Hopefully another bit of the learning curve to ascend here.
All the very best for now
Anthony
