I don’t know what to tell you. I just tried the combination of Carousel 2 and HTTPS Helper on a new blank page, and it worked the way I would expect it to.
In fact, this reminds me that the latest version of Carousel 2 already uses HTTPS by default, and there’s no way to turn it off. Try downloading Carousel 2 again, and re-installing it in the following manner:
- Download from ActionsForge: Carousel 2 - ActionsForge
- While Freeway is running, drag the downloaded Action on top of Freeway’s Dock icon.
- Ensure that you see the warning dialog: You are about to install Actions that replace existing Actions. (wording is not precise)
If you don’t see that warning, then what that means is your document is cacheing an older version of the Action, and you don’t actually have the Action installed on your Mac where Freeway can see it. So if you see a different warning (You are about to install Actions, or something like that) then that means you are installing it for the first time. And that could explain a lot, too.
After you do this, hold down the Control key and choose the hidden option Publish Everything from the File menu. Then upload, and see if the problem is resolved.
If this still doesn’t fix things, try creating a new document (as a test), drawing a single HTML box on an otherwise empty page, applying Carousel 2 to that box, and publishing. View source on the page from within your browser, and see whether there are these lines in the section of the page:
<script src="https://ajax.googleapis.com/ajax/libs/prototype/1.7/prototype.js" type="text/javascript" charset="utf-8">
</script>
<script src="https://ajax.googleapis.com/ajax/libs/scriptaculous/1.9/scriptaculous.js?load=effects" type="text/javascript" charset="utf-8">
</script>
<script src="https://dnk2vbhoq39rr.cloudfront.net/carousel2/0.2.0/carousel2.js" type="text/javascript" charset="utf-8">
</script>
Those are the correct links that you should see: note the https:// prefix in them. That’s what I see here when I apply Carousel 2 to a page element. Your page as published has the http:// links in it.
On Jan 9, 2019, at 10:25 AM, Carla email@hidden wrote:
ok Walter… I went back to apply the page action and all sorts of republishing… its just not working on the site.
Im not sure what to do next
C
