Hi
Can anyone explain where is the ‘Target Picker’ so I can get Carousel to work?
Below is an extract from the the guidance found here: http://www.actionsforge.com/actions/view/283-carousel-2
Construction
Draw an HTML box where you want your effect to appear. Either double-click inside of it and build your first pane using inline layout techniques, or draw nested elements within the first pane (click once on the pane so its handles are showing before drawing each element within it). Duplicate this box, then apply the Carousel 2 Action to the original.
Apply Carousel 2 Pane to the duplicate box, and choose the first box in the Target picker. Modify the contents to become the second pane of your animation. Duplicate this second pane (and modify each copy) enough times to complete your effect.
