Hi - for some reason I cant get the Carousel 2 to play nice - it seems to want to appear at the bottom of the page - not in between the two shadows I created?? Even though in the FW dock the surrounding box is highlighting telling me the C2 pane should be there?
You have jQuery in the same page. Any particular reason? Also, you have applied the vertical class to a parent element way above the carousel itself, and it’s been wrapped in two layers of DIV before we even get to the carousel itself. That shouldn’t mean anything by itself, but it might be confusing things.
Try simplifying the layout considerably. I have tried this Action in simple inline constructions, and it worked okay there, but nothing with as many layers of wrapping as this layout.
Remove jquery and see if that fixes it.
Un-nest your carousel element and float it above the entire page and see if that fixes it.
Let me know how you go. I may want to move my signaling out of the element classname and into more data-attributes, just to avoid these clashes, but as I said, I don’t believe that should be the issue directly.
Just popped out but will back in an hour to test. Yes def think that jquery code will be the problem! Jess! I duplicated from home page that’s why it sits there forgot to remove (again! Done this so many times!!)
