I am not 100% certain about this but this option is not set on initial installation of FWP, once you set the option any further updates you make to FWP will use the existing Preferences, so there is no need to reset the Option every time you upgrade your FWP.
I seem to remember setting it initially when i was learning FWP 5 and then when i upgraded to 6 and then 7 i cannot remember resetting the option.
Each major version of Freeway copies over all that it can from the previous version’s preferences files. If you ever set this on (and you would have if you used any of my first-generation “Scripty” Actions, you would have preserved those settings across multiple major (and minor) versions. Moving to a new Mac can disrupt this, depending on how well the account migration system in Mac OS X works.
