[Pro] Carousel and Spawn New Window
Hi the experts,
just a quick note about a thing a stumbled that morning. I have an old page I seldom actualize, but I recognized, that the above mentioned actions seem to not play really together. While the spawn works, the carousel stopped working.
The message had been:
I actually removed the SNW action on my project, so I can’t reproduce the mistake for you.
If somebody could have a look in if it is just me or if you could double this experience?
Thanks and Cheers
actionsdev mailing list
This sounds like the version of SNW and the version of Protaculous were not in synch. Freeway 5.6.2 introduced a new generation of Prototype/Scriptaculous libraries, and all of the other “Scripty” Actions had to update to match. SNW uses these libraries for its iOS compatibility mode. The way that the Scripty Actions interact with Freeway during the publish process means that the last Action “wins” and publishes all of the related libraries to the page. If that winning Action doesn’t include the same handler code as all the other Scripty Actions on the same page, the publish process will appear to work, but will actually result in (possibly) multiple requests for different versions of the same libraries, and that can produce the kind of error you noted in your Gist.
Just a tip for future – when adding a Gist, just put the URL of the Web page on a single line:
http://pastie.org/3607529
There’s no need to add the script tags.
On Mar 16, 2012, at 7:42 AM, Thomas Kimmich wrote:
Hi the experts,
Thanks and Cheers
what will mean that Paul needs to update (sync) SPN or that we have to live with it?
I always try to keep that in mind, and I always do it wrong, arrgn - (the pastie or the gist).
Thanks so long.
I thought he did this quite a while back, check with his site to see if there’s a newer version. Also make sure you have the very latest of all of my Scripty Actions (Protaculous is the one you need for Carousel, but there’s a handful+ others that use the same library.)
OK excellent. To find the hair in the soup: AF says 4.0.6 (what I had) but the actual version is 4.1. If I could have wish, I’d wish an “action auto update” mechanism - oh what a charm.
I think that would be marvelous.
