When I use Carousel with an Auto-Glide of a few seconds I expected the Auto-Glide function to cease if the user clicks the ‘Next’ or ‘Previous’ Carousel buttons, but this doesn’t seem to be the case.
It still progresses to the next Pane even if the user has specifically clicked to view a particular Pane, which doesn’t seem right.
There are new features in the latest version of Protaculous Protaculous - ActionsForge (which contains the Carousel stuff) - which allows you to set a button as Start Auto-Glide or Stop Auto-Glide.
