[Pro] carousel direction conflict?
Hi, I am having trouble with 2 different carousels on the same page, one is set to scroll horizontally and the other is set to scroll vertically, the first is quite large and the second is really small. The small one set for "vertically’ is functioning horizontally. I’ve rebuilt it to make sure there were no errors and still get the same result. Each carousel is built properly with its own controls and grouping. Is it possible to do 2 separate directions (and 2 very different size carousels) on the same page? Thanks, Bob
Yes, I know I have tested this combination before. Can you post a link
to the page in question?
