Hi,
I am trying out FW Pro 5.6.1 on OS X 10.7 and using Carousel action version 1.2.16. I was able to open sample files which work fine.
But if I try to copy over sample or create a Carousel on my site, I cannot get it to work. At most I can get 2 slides to work, but that is it. I followed the instructions on Carousel in Freeway but am stumped.
Are there are any known issues with the versions I referred to above or any changes to instructions?
Thanks in advance!
George
actionsdev mailing list
