Okay, I have spent a couple of days reading and applying the tips I gleamed from the threads. Much of that time on the “One-Dot-Oh” thread. Walter helped me on my original issue with the carousel not working and that issue was corrected. However, now I am stumped again and I hope someone will be able to direct me.
I am developing a website and I would like to utilize the “Carousel” action through out. My “home” page has a carousel that is working just fine. However, I can’t seem to get the second page to cooperate. Maybe, I am expecting too much.
My goal was to have 20 tabs that would carousel pictures in 20 Carousels (each Carousel would have 6 to 10 images), and there would be “next” and “previous” buttons for each Carousel.
I have redone the Carousels a dozen times or more, using the original instructions and the tips I learned from reading the threads. Every individual item is pointing to its proper point. Tabs to the Carousel, Carousel Panes to the proper Carousel and the buttons are pointing to the proper Carousel.
However, what happens is that the only Carousel that plays is the last one I built. The first two do nothing. I have even used the “Publish Everything” command to make sure all is collected.
The links to the website for anyone who can help are:
http://www.ergopetdiner.com/index (this one is the working one)
http://www.ergopetdiner.com/ncaa (this one is the problem child)
The tabs to check on are the “Gators”, “FL State” and “Bulldogs” tabs (which are the top three tabs on the left). No matter which tab you click on, only the UGA diners work with the buttons. I tried to do it as an “auto-Glide” and it will play all of them and not just the ones assigned to the tab.
Am I expecting to much from the action? If so is there another that will allow this type of action? Would the “NewsCycle” be a better choice?
Thanks in advance for your suggestions and help.
David Hamill
Middleburg, FL
