Hi,
I have a working carousel with 3 panes using the Carousel action and the panes use the Carousel Pan action. I added a fourth pane.
I am unsure how to get the new 4th one I added to be third in position of showing, and the old 3rd to be 4th.
I tried removing the c.p. action from #3 and it did bump #4 to #3, then when I added it back it, it went back to its original #3 position.
Hope this is clear.
Thanks for any reply,
Barry
I found it!!!
I had to change the order of the items with the triangles in the site panel. Simple- thanks Walt.
I really wish there was a way to delete a post when I find the answer right after I post so people do not waste their time opening to help.
Thanks all!
Barry
But others who come along after can see your solution if they have the same issue - a valuable resource.
That is why it is important to end a thread like this with a conclusion. ie “I did this and it did that and it was fixed hooray!”
Nothing worse then providing feedback to a poster to never hear anything from them again. You are always left wondering…
Yea- but in this case I found the answer on the forum (i.e. I posted before looking for some reason) and then deleting it would help those find the better thread, not my “filler” thread.
I see people do that often (not tell what their result was)- I always tell the result and it is usually a great one thanks to DAVE!
new Hoffkids goes up tomorrow!!! 6 months of work!
Barry
The answer is in your statement: ‘I posted before looking’
The forum here is email based - you cannot get an email back once it is sent!
