What’s the best way to handle Carousel Panes in terms of organization?
I usually expand my pasteboard to about 1000 pixels wide and then place them at the bottom in columns and rows so I can easily access them, if needed. However, I have noticed that placing a Carousel Pane near the lower right hand corner of the pasteboard can cause unusual things to happen with the layout when previewed, like that Carousel Pane showing up at the bottom of the previewed page.
If that Action is properly applied, this is completely impossible. The entire element that Pane is applied to is removed from the output HTML and moved inside the carousel element. In the process, all of its positioning code is stripped away from it. Check to be sure that every element within that pane is properly nested inside the one element to which you have applied the Carousel Pane Action.
