I love Carousel and have found all sorts of uses for it, particularly at the following site development location: www.salarpursuits/test_run/watches.html.
Here’s my problem; everything works fine using the thumbnails on the right as Carousel tabs, which call up each watch in turn. Each panel has a graphic-based ‘Add to basket’ button, suitably coded as a ‘submit’ button and they all link to Roman Cart (no choice here, client’s wishes). However, the watch tabs labelled PRG40B and PRG80L both link nicely to Roman Cart, whereas the PRG40 button just takes the visitor back to the Intro panel (Carousel base pane). What’s going wrong? Clearly there’s a heirarchical aspect to this scenario. Might I solve the problem with the PRG40 pane by adding a ‘target’ value after the URL in the … part of the HTML?
I’ve checked the HTML using TextWrangler and everything seems fine. The
