When using the Carousel Action Script, anyway to control how fast or slow a Carousel pane slides in?
If you have the latest version of the Action, then you can change the
Effect Duration setting to whatever time you like. Default is a half-
second. Enter a decimal number of seconds.
Are you referring to how fast the panes visually slide or ease in?
Where do I get the latest version of the plugin?
Thank you waltd for such and awesome Action script!
Best,
John
Yes, the duration of the effect governs how long it takes to switch
panes. If you have a lot of panes and a very short duration, they will
“whip past”.
You can get the latest version at ActionsForge: http://actionsforge.com
You’re welcome!
Best,
John
Awesome waltd. Thank you so much for your generosity in providing such a invaluable tool like Carousel!
