I’m trying to make a page to display three different carousels. Initially the page would have three buttons and no carousel visible. The viewer would click on a thumbnail button and the related carousel would appear along with the carousel ‘next’ and ‘previous’ buttons.
I’ve made the three carousels, and they work individually when I test them. Then I put the ‘show/hide layer’ action on each carousel and stacked them on the same spot. I set each to ‘initially hidden’, and gave each a unique target number and then set the same click number on the corresponding rollover button.
When I test it the carousels are hidden, but when I click the rollover buttons, they never appear.
Am I going about this the right way? Is it possible to do what I am trying to do?
Also, if you want to look at what I will look at once you publish this
somewhere I can see it, simply open your Safari preferences, click on
the Advanced tab, and check “Show Develop menu…”. Once that’s
enabled, you choose Develop / Show Error Console and look for anything
in red. That’s the starting point. Understanding the red words comes
later.
On Feb 25, 2011, at 7:35 PM, DeltaDave wrote:
Do you have an example page online that we can look at?
