I just saw a second element on the page (below the top section, which was what I was responding to) that does look like a Carousel effect. If you’re wondering how to get the text across the images, remember that the ScriptyCarousel may be applied to ANY element, not just a single image or single HTML box.
If you draw a graphic box, import your base image, and then while that box is still selected (corner handles showing) draw another graphic box over the top of the first and use that as your text box, then you can use the composite element as your carousel element.
If you look at the demo page for the Action, you’ll see complex composed panes, with HTML text and positioned graphics combined into each pane.
http://scripty.walterdavisstudio.com/carousel/carousel.html
On Jan 25, 2014, at 11:13 AM, Walter Lee Davis wrote:
Actually, that looks a lot more like an Accordion effect. Try using the ScriptyAccordion, in horizontal axis mode. Use a graphic box as the header, and an HTML box (div) as the disclosure area. You will need to do a little fiddling around with the initial construction in Freeway – there are floats required to make this work, and there may be a visual disconnect between what you see in the design view and what you see in preview or in any browser, depending on which version of Freeway you are using.
On Jan 25, 2014, at 6:10 AM, colin hart wrote:
Hi can anyone help me with trying to make a carousel like the top one in the link provided?
I can make a normal one but would really like to add the tags like on the one in the link
http://www.thamesgate.com/
