Yes but not as easy as the action.
Try this
Create an HTML box over your page, give it a name (ie gradient) and then apply the CSS3 gradient action to your box and style it how you want it to appear.
Publish your page and look at the source code - look for the style called #gradient. It should look something like this
#gradient {
background-image: -moz-linear-gradient(top, rgba(0,255,255,0.8), rgba(255,0,255,0.8)); /* FF3.6 */
background-image: -o-linear-gradient(top, rgba(0,255,255,0.8), rgba(255,0,255,0.8)); /* Opera 11.10+ */
background-image: -webkit-gradient(linear,left top,left bottom,from(rgba(0,255,255,0.8)),to(rgba(255,0,255,0.8))); /* Saf4+, Chrome */
background-image: -webkit-linear-gradient(top, rgba(0,255,255,0.8), rgba(255,0,255,0.8)); /* Saf5.1+, Chrome 10+ */
background-image: linear-gradient(top, rgba(0,255,255,0.8), rgba(255,0,255,0.8)); /* Standard CSS3 */
Copy the code and paste it into the before end head section of Page>HTML markup within some script tags. Change #gradient to #PageDiv
You will then get something that looks like this
<style type="text/css">
#PageDiv {
</style>
Remove the box and the action from your page and preview and you should get something like http://deltadesign.co/css3/CSS3_Gradients.html
