t50ufo1
(t50ufo)
October 1, 2014, 1:36pm
1
In my example page here the ccs menu text appears on top of my fixed top bar at the top of the page at some responsive browser widths. Everything else is underneath OK. When the menu breaks to the hamburger it too is on top. Any thoughts why this happening?
http://www.trevormckay.co.uk/caption/
Your CSS menu has a z-index of 9999
z-index: 9999;
So you are going to have to go 1 better on item1
Item Extended > Div
New
Name: z-index, Value: 10000
t50ufo1
(t50ufo)
October 1, 2014, 8:29pm
3
Thanks Dave
I did see a thread about z-index and had an idea that was what I needed!
Didn’t know what the settings should be. That is another small step!
It does depend on individual page layout. Because you have a fixed header like that you need it.
Just a thought - this may screw up your hamburger menu.
t50ufo1
(t50ufo)
October 2, 2014, 8:31am
5
Thanks Dave
That didn’t work!
deleted all on test server and replaced here:
the static bar item has been renamed “topstaticbar”
for identification.
If there is no easy fix - I can make the bar scroll with the page.
t50ufo1
(t50ufo)
October 2, 2014, 12:18pm
7
Thanks Thomas
That sorted the problem right away!
t50ufo1
(t50ufo)
October 2, 2014, 12:20pm
8
Thanks Thomas
That fixed it right away!
NOT
Just as well Thomas is paying attention!
t50ufo1
(t50ufo)
October 2, 2014, 8:00pm
10
No problem Dave
Thankful for all the help I get here.
