Hi,
how do you change the opacity of html box background colour?
thanks in advance
Peter
Hi,
thanks in advance
Peter
Hi Peter,
usually the “image” way to make a small png (or gif) and apply it as a bg to the html-item.
But you could try as well the css way.
Add this into the before head of your page:
Draw a HTML iten, click extended and add in the div section the value pair
class (name)
transparent (value)
Set a color and hit cmd-D to produce another div. Give the second one another color using the inspector.
Preview and both divs (having the class name “transparent” applied) will be in that case 50% (0.5) transparent independent of its color set via inspector. Play with the values 1.0 (opaque) - 0.1 or whatever.
Hope this works as expected.
Hi Thomas,
thanks again, using the gif method.
Peter
Hi Peter,
excellent.
Just a quick note for others want to try the CSS method.
This:
class (name)
transparent (value)
should read:
Draw a HTML item and while still selected (or click to select) choose item, extended add in the div section the value pair
class (name)
transparent (value)
Much much easier way to do this:
On May 8, 2012, at 5:49 AM, Peter Walsh wrote:
Hi,
thanks in advance
Peter
thanks Walter will do.
Peter
Walter,
do you know how to get bam boxes to appear at different places under a css menu or each one appear in the same place?
example below but they all appear just below their menu name.
link below to tests I’m running
click on client area
login: freeway
password: softpress
thanks in advance
Peter
See your other thread for a link to an action for this Menus
