You can do something clever then. Create a visited link style that includes a checkmark background image or similar, and the normal browser behavior will check the box for you.
Make two separate GIF images (exactly the same size), one, an empty checkbox, and the other filled, or jauntily crossed out or whatever. Make this in Photoshop or similar.
Then, in Freeway, click on the HTML box that holds the links you’ve made (assuming that they are all in the same box – it’s much easier that way). In the Inspector’s style tab, click open the Links segment, and click on the More… link below the basic boring styles. You’ll enter the advanced link style editor, which looks a lot like the regular Edit Style (CSS) editor in Freeway’s Styles palette.
There, you can apply a background image to the normal link (look in the Character picker). Set it to align left and vertically centered, and no-repeat. Then click the Extended button, and the New button in the Extended sub-dialog, and in the resulting sub-sub-dialog, add the following Name/Value pair (this is assuming you made your checkbox images 16px square):
- Name: padding
- Value: 3px 0 3px 20px
Okay out of that dialog and the Extended dialog. Now click on the Visited option, and only set the background image to your checked image. You don’t have to set any of the other properties, because they are inherited from the link itself.
Preview in a browser, and you should see one or the other checkbox image, depending on your browser’s history. You can erase the browser’s visited history in the browser’s preferences so it will show you the un-checked image again if you like.
On Sep 29, 2011, at 1:51 PM, GregB wrote:
Hi Walter,
I’m using a seperate page for each video - user clicks on the link and goes to a new page and then can either click the ‘back’ button to return home or I will also be adding a ‘main menu’ link on each page.
Video format I’m using is mp4.
