[Pro] check .swf-Plugin
What do have to do on a FW5 Pro Website to check whether a swf-Plugin is installed on a users browser or not and direct the browser to a swf-movie or a static html-site?
Thanks for your answer,
Jan
Hi Jan,
There’s a tool called swfobject that will do this for you. There isn’t
anything built into Freeway that will do it for you though so you’ll
need to add the code to the page yourself:
Hope this helps,
Jan
