i have 3 groups of circles with rollover to change colour (big middle and small, small inside the middle and middle inside the big one) but when i pass my cursor it starts changing before i touch the border of the circle because of rectangular outline that freeway makes when you create a circle graphic item… is there any way to solve it?
You could try drawing a circular map area, and attach your rollover to that. I am not sure it will work, but it’s the only way to have a rollover respect the visual shape of a non-rectangular object.
If that doesn’t work, draw a circular graphic box, import your graphic into that, and apply your Rollover Action to the circular box. Freeway will draw a map behind the scenes, and it may apply the rollover behavior to that map. Not sure, I never do this myself.
