What exactly is the purpose of the clear.gif that is always generated by FW?
I’ve set up an html e-mail for someone and there are no images or art, but the page looks different with it and without it. I didn’t really want to give the client any images, but it seems it needs the clear.gif to look correct, but I have no idea why.
Clear.gif is typically used as a spacer to reinforce a table layout. I’m not sure, but you could try going into the ‘Document Setup’ and see if the box ‘Reinforce Layout Tables’ is checked. If you delete that then perhaps it will go away, but I haven’t tried that.
