dadooper
(dadooper)
1
hi everyone,
is it possible to make a clickthrough questionform (don’t know the exact name) in Freeway? Kind of like the example here: http://ekantoor.djbnotarissen.nl/flex-bv-doe-de-3-minuten-test
regards,
dadooper
Yes - here is something that uses this method http://www.deltadesign.co/fw_examples/walts_scripts/index.html
dadooper
(dadooper)
3
Thanks for your reply Dave. I will check it out.
