swfobject.js Failed to load resource: the server responded with a status of 404 (Not Found)
subscriberworkv1e.php:10 ReferenceError: Can't find variable: swfobject
So the swfobject file is not where the script expects to find it.
swfobject is used to display flash files like your expressInstall.swf
Hi Jan,
If I look at your page using Safari’s Web Inspector (see below) I can see that it is throwing up two errors;
The browser can’t locate the file called “swfobject.js” (the 404 error) and then because of the missing file it then doesn’t know what the variable “swfobject” means.
Either FTP the swfobject.js file into the same folder as this html file or use an Action like Upload Stuff (http://www.freewayactions.com/product.php?id=032) or Upload Extra Resources (ActionsForge - The Complete Repository of Freeway Actions) and you should see the error go away.
