t50ufo
(t50ufo)
January 8, 2010, 3:04pm
1
Hi All
Just purchased this piece of Javascript
http://codecanyon.net/item/my-products-zoomer/full_screen_preview/53356
and I have posted included Instructions here:
http://www.trevormckay.co.uk/readme.html
based on the sample above (I have the images)
how do I get this to work in Freeway?
The script and the CSS should be referenced in the before end head of Page Markup
<link rel="stylesheet" type="text/css" href="RbZoom.css" />
<script type="text/javascript" src="RbZoom.js"></script>
These 2 files should be uploaded to your server using either the Upload Stuff action or by FTP to go with the HTML file that will use them.
As to the images themselves - the small one should be placed on the page as normal. The larger one uploaded using the previous method.
Create a link on the small one on your page using external with the path to your larger image in the main box and then Click extended and add the name, value pair of class:RbZoom
That should do it.
There are other methods but this should get you started. Pay particular attention to where you are uploading the images and use the correct path.
t50ufo
(t50ufo)
January 8, 2010, 4:36pm
3
Hi David
Thanks for reply and help. I will give this a go and let you know.
t50ufo
(t50ufo)
January 8, 2010, 5:01pm
4
Hi Dave
OK Here is what I did
Placed 2 lines of code in HTML Markup
Before
Placed small image on Page as normal
Uploaded large image to a folder on server
Created link on small image using external with path to large image
On small image on page clicked extended and entered name= zoom
and entered “RbZoom” in value pair
Uploaded 2 files to same folder as the index page
I get this:
http://www.trevormckay.co.uk/zoomx/
entered name= zoom and entered “RbZoom” in value
name=class and value=RbZoom
Try it with those
t50ufo
(t50ufo)
January 8, 2010, 5:16pm
6
Sorry Dave
No Change
T
You appear to have added name=class and value=RbZoom to the small image not the Hyperlink to the large image.
Click small image Edit>Hyperlink and enter the path to the large image (which you have done) and then just below that path there is an Extended button there where you add name=class and value=RbZoom
Just noticed that you have also have the links to the css and stylesheet placed before HTML rather than before end head
t50ufo
(t50ufo)
January 8, 2010, 5:46pm
9
Good Man Dave
That works . . .
Now can I really pick your brain
as to how to implement the two small thumbnails as in the original.
I know it’s Friday night now - if you can help - in your own time - no rush
Thanks and have a good weekend - even though it is FREEZING!
chuckamuck
(chuckamuck)
10
I notice this relies on jQuery. If you using some of the built-in Freeway effects there may be a conflict between javascript libraries.
t50ufo
(t50ufo)
January 8, 2010, 5:50pm
11
Thanks Chuckamuck
Seems to work OK on my test page - see my last post
Dave
Sorry, Not clear on the “before end head”
which one is that on the dropdown list
T
If you look at http://deltadzine.net/rbzoom.html
You will see it - it comes under Page>HTML Markup
t50ufo
(t50ufo)
January 8, 2010, 6:05pm
13
Thanks Dave
Got that OK (Before ) and changed it.
Thank you for your time
T
OK Trev - Example with the thumbnails http://www.deltadzine.net/zoomify.html
t50ufo
(t50ufo)
January 9, 2010, 12:07pm
15
Wow Dave! Great examples!
The second version is exactly what I need.
I will be using this for a Fashion site so want to show
two thumbnails that show front of garment and
back of garment
then hover to show detail.
EXACTLY as your second example.
Can you guide me through the process please.
t50ufo
(t50ufo)
January 10, 2010, 8:36pm
16
Hi David
Just a short note to thank you very much for the working freeway example files and notes you sent me via email.
I now have a test page with an RbZoom image fully operating thanks to your help to a stranger over a weekend.
I am always amazed at the help I receive on this forum from the kindest of souls like yourself - always keen to share knowledge in a clear and helpful fashion.
Best wishes to you and again THANK YOU
Your welcome Trev
Just trying to reciprocate the help that I have received here over the years and continue to need!
Can you also send me the example files and guidance notes as well? Thanks
in advance.
Best Wishes,
Lawrence
2010/1/11 DeltaDave email@hidden
Your welcome Trev
Yes Lawrence if you let me have an email address. You will get mine from the ‘People’ list on the FWT website.
Thanks in advance. My email address is: email@hidden.
2010/1/12 DeltaDave email@hidden
