I may be way off beam here, but really it was pretty simple. I simply used the code referred to below in a FW markup item, defined the paths to site and song fully in the xml file, uploaded everything to the same root folder on my site, and it just worked.
I know you are much better at this kind of thing so I wouldn’t presume to tell you how to do it, maybe it was beginners luck, but it did work!
Somewhat mystified.
atb
Dick
code:
This text will be replaced by the flash music player.
On 5 Mar 2010, at 18:40, Walter Lee Davis wrote:
Okay, so what you need to do (after you drag the thing into the page) is click once on the Flash movie element, choose Item / Extended from the main menu, and then click on the segment of the dialog, then press New, and enter
name |
value |
playlistPath |
playlist.xml |
And upload. You’ll also need to upload playlist.xml to the same folder as the Flash movie (usually Resources). If the player doesn’t work, then try adjusting playlist.xml to another value. It’s hard to tell if you didn’t write the Flash where it looks for the source file, whether it looks relative to the movie or the page.
What you can’t do is to enter a complete URL to the file, that will just run afoul of the Flash security system.
On Mar 5, 2010, at 1:09 PM, Dick Tapsall wrote:
Hi Walter
As far as I can gather this is all I needed to get the player to work. Link is:
