Doty1
(Doty)
1
Is there any way to “unlock” the unused colors from FW’s default color palette so I can delete them?
I’m guessing no, but hoping there’s a way.
The locked colours are all the Primary ones that you cannot edit - there should only be 8.
Anything else may be duplicates/used.
Doty1
(Doty)
3
That’s what I figured. Thanks David. Of those 8, I typically only use 2-3 and I was hoping to purge the others. I’ll live with it.
Richard
(Richard)
4
But indeed … it would be great if you could delete all of them, not just the custom ones.
Doty1
(Doty)
5
In addition, I wouldn’t mind the ability to “lock” my custom colors like the default set colors. I’ve inadvertently “deleted” a color before!
FW always asks you to provide a substitute if the colour is in use - that should at least get you to double check.
