I would like to know how I am able to achieve a look similar to the one displayed in the referenced url. The main portion of a page is to be in white, but I would like the portions of the page that are left and right of the main window to be a different color.
Yes it was me that pm’d you. Thanks for replying to this thread. Yes, I am using FW 6+. I have tried your suggestion and when I do, here is the result: setting either the page or window color to efefef results in the page only changing color.
I accidentally pasted the wrong url before. Here is the correct one:
I created a blank page and am still unable to get the window to be one color and the page to be another.
I did not draw any html boxes. I simply changed the window and page colors and previewed them. The only color that was visible is the page color (the window color was ignored).
set the page-width to maximum (980px) instead of flexible cause flexible means, that the page width = browser window width and therefor the pw covers the bw.
I am not sure why you set the page-width to flexible (cause your construction doesn’t show any necessity for), but if, you have to remove the page-background color and wrap all your content in a “page-wrapping-item” which has the wanted color instead.
