Has anyone setup a webpage for comments using either Disqus or Echo Realtime Tidbits/Comments, with a Freeway website. I would like to see samples of each as well as get input as to how difficult it is to install and maintain.
It’s pretty easy to work with (Disqus). You would just have to replace two parts with your siteshortname and then the other with the full URL to the page.
I use it on my site, however since it’s a blog style page I had to dynamically set the URL which if you’re not using a CMS system (ExpressionEngine, Joomla) you would have to write in the URL manually for each page you used it on.
