[Pro] Comverting Pro Template
Moving from Express to Pro7 where Templates show massive change in structure from Express 5 and 6.
In Express can replace most items in a template, and the index/home page image especially. In Pro Esperanto Template a full width photo is locked (red dots) and no found to replace it.
Deteting it doesn’t leave a place it in the templet so far as I see. So how do I insert a new pass thru image? And in what.
Where’s references to the DIFFERENCES in master page layout, as ALL items on the pages seem to BE in and remain in/on the MASTER.
Rather confused.
Moving from Express to Pro is a big change because the layout possibilities with Express were quite limited.
Everything on the SP templates is editable - I don’t own any but I know this to be true.
You have to look at your page differently.
To find where you need to change this image you need to find the HTML container for it first.
The easiest way to do that is to change the Left Hand sidebar so that it reads Page and not Site - and you do this by clicking on the Site/Page header - this will then reveal all the items on your page.
The one you want is called Body
If you select it (Body) in the sidebar you will see it’s attributes in the Inspector - and that is where you can select your new image to replace Deathtostock… Whatever its called.
Sorry not at my Mac just now to provide a screenshot but that should help you on your way.
