Walter, thank you for the comparison page. But I know that a page with nothing but a search field works. It’s just that, for whatever reason, on my actual web page you see this mess in Mobile Safari:
Nevertheless, I have viewed your example page in various browsers. Here’s my report:
IE7: Displays the “if lte IE8” conditional statement in plain text, directly above the search field. The rounded-corner search field displays, but there is a thin blue border that goes around it, off center. Furthermore, when you insert your text cursor inside the field, the cursor is up too high and it overlaps the little magnifying glass icon.
IE8: Didn’t test because a co-worker was hogging the PC.
IE10: Displays fine. Clicking the magnifying glass doesn’t do anything special.
Safari: Displays fine, and clicking the magnifying glass displays a popup.
Firefox (OSX): Displays fine. Clicking the magnifying glass doesn’t do anything special.
Firefox (WinXP): Similar to the display in OSX FF, except the text inside the field is a little scrunched.
Chrome (OSX): Displays fine. Clicking the magnifying glass doesn’t do anything special.
Chrome (WinXP): Displays a rectangular search field, and the color of the magnifying glass becomes blue, and clicking the magnifying glass does nothing special.
Mobile Safari (iOS6, iPad3): Field displays differently than desktop PC browsers. It looks the same, except there is no magnifying glass icon on the left side. No problems though.
Based on this analysis we can see that the look is not 100% consistent across all browsers and platforms when we use Type:Search to override my sprite in webkit browsers. Furthermore, something is conflicting on my actual web page that prevents proper display in Mobile Safari.
I think I’ll take the 100% consistent look by giving Webkit users the same shaft I give everyone else. They will all get my sprites.
James
P.S. When you have time to comment on HOVER CLASS triggering…
http://freewaytalk.net/thread/view/129272#latest
