I am having a slight problem on a site but only with IE. As the slideshow rotates it affects the scroll bar in the text box “Weekly Parent Bulletin” causing the user to loose control of scrolling. The scroll bar extends to the length of the box (both ways) & then goes back to the way it was. It’s the blink of an eye quick but when you’re scrolling & it happens, you lose control of the scroll.
I’m at a loss as to a fix. Can someone take a look and guide me to a fix. Thanks so much.
