Hello, I’ve created a contact form on my website, www.greenscapeorganics.com. Everything works fine, except I don’t receive the email after the form has been submitted. I downloaded the PHP Feedback Form Action. Everything is set correctly in the action, and I have even tried turning the “use GoDaddy’s mail script” off and on (they are my host) but it doesn’t seem to make a difference. Thanks for the help!
Yes, I had set everything up correctly in GoDaddy. I called them this afternoon, and unfortunately the PHP form (I think that’s what it’s called) can only be used with the primary domain on my account. I asked if there was some sort of add-on, and the answer was no. This seems ridiculous as I have 10 domains hosted under my main account…so none of them can take advantage of a contact form. Any ideas on how to get a contact form working without using GoDaddy will be greatly appreciated!
