[Pro] Contact form..
please help i keep getting error when trying to send a message
don’t know whats happening.
Please help
I assume that you are using the PHP feedback form action?
If so then you have to be careful about naming your fields correctly.
Name should be - name - case sensitive
Email similarly - email - also case sensitive
With the field selected look under the 3rd Tab in the inspector for the correct naming.
You will also have to rename the pickers for the start and finish times - you have all the starts set as Party Start Time.
These should be different for each ie party start hour, party start minute and party start before/after
Similarly for party finish etc.
If those changes aren’t enough then set a different error page for each error - just create a basic page for not in domain,server failure, invalid email error etc
Not a good idea to have another contact form on each error page once you are down to the one (multiple error pages are only for testing). Better to have a link back to the original contact page. Like this form does. http://www.deltadesign.co/formtest2.html
Thanks dave
will change tomorrow…
can you you try it for me?
I am not seeing any changes
Name and Email fields still the same Name, Email
Appears to be only 1 error page as well
These are what I would like to see for error pages
http://www.deltadesign.co/servererror.html
http://www.deltadesign.co/notindomainerror.html
http://www.deltadesign.co/error.php
Did you make/upload the changes?
Who is your site hosted with?
Hi Dave,
Ive made the changes now but its still not working…
My site is hosted with 123 reg…
Just tried it and it sent me to the success page.
Is it working now?
If so what was the issue - share for others that may have the same problem.
