I am in the process of setting up a site for a new client using Walters carousel action suite. It all appears to work fine in Firefox 3, Safari 4, Omniweb 5 but the swf file does not disappear in Camino or Opera, just sticks on the left of the main window.
Could some kind person or persons please check it out for me on IE in Windows and let me know what happens
Flash content is one of the “known issues” with this system. You might
experiment with setting wmode=transparent on the Flash elements. The
basic issue is that Carousel hides content by placing it in a DIV that
has overflow set to hidden, then moving the content outside of the
bounds of that container DIV. If plug-in content is hidden in this
manner, it may or may not work, depending on the individual browser,
the implementation of Flash within that browser, the alignment of
Jupiter with Mars, any number of things.
On Sep 3, 2009, at 12:07 PM, diarbyrag wrote:
Hello all,
I knew you were fast but that is a Hyperfast response…
Thanks, I will try what you suggest, my only other idea is to make the carousel content window larger with white space each side and see if the overflow ends up out of the browser window ?
