accidentally when I try to publish, preview, or preview in browser, FW opens an attention box: one or more html file that do not belong to this site will be overwritten. do you want to continue?
it’s driving me crazy I did everything, but I cant publish.
Try setting a new Site Folder in your Document Setup dialog. This is
not a crash, it’s a warning that Freeway is going to replace files it
doesn’t know about from the current document context. This is usually
a sign that you have reused an old site folder with a new document.
Nothing serious, in other words, because the next time you publish
from that other document, the inverse will happen, and this document’s
files will be overwritten.
This alert simply means that Freeway believes that the files in your Site Folder belong to a different site. This can occur if you publish more than one site to the same Site Folder, or if Freeway loses track of the published files. Generally, it is safe to say accept the overwriting and go along on your way.
However, if you want to be safe and not overwrite those files, the best thing to do is to go to File > Document Setup and choose a new Site Folder from there. Freeway will then publish your site files to that new folder and the error will clear up.
Hope this helps,
Katie Wagner
Technical Support Operative
Softpress Systems Ltd
SOLVED!
so what was the reason? I cropped one of images that I used in my pages using Preview. as I’m on Lion, I used versions feature to turn it back to what is was and freeway stops crashing.
