On 15 Oct 2010, 12:46 pm, Thomas Kimmich wrote:
Yes - maybe partially - in fact the master point of the question is:
why is your sourcecode pointing to a fiResources folder and not to the “common” Resources folder FW is creating by default?
I have no idea how that non existent folder name has been formed and I agree with you that it looks suspicious. I may have an explanation but not the fix. Folder leafname concatenation is crooked in this case.
My site is in 3 languages, Finnish, English and French. All page files are located under 3 directories: /fi, /en and fr/. I manually created these folders in FW and manually create my page instances under either one of these folders. It is the way recommended by softpress, if I recall, and that suits me fine. Until I applied an email create action…
Now, I have the feeling that FW concatenates wrongly the subdirectories, adding from times to times an un-needed leaf name, hence the “fiResources” instead of likely “Resources”. I had a look at the content of the links I formerly created in the pagethat you modified below and… some of them are broken, holding one of these extraneaous leaf name. I verified these are broken as well the same way in the original built file upkoaded from my computer. The crooked links are:
http://www.celticcenter.eu/fien/home.html → “fien” should be “en”, extraneous “fi” added here
http://www.celticcenter.eu/fifr/accueil.html → “fifr” should be “fr”, extraneous “fi” added here
http://www.celticcenter.eu/ficentre.html → “ficentre.html” should be “centre.html”, extraneous “fi” added here
Do we have a pattern here? I am not sure. Why “fi” and not any other folder name? Finland is the country I am living in but, well… I am lost for now. What I know is that my email page is not usable.
It’s this part: look at the img src=
neither path nor filename matches the needs.
I cleared up this and set the path and name to what it should be:
http://www.kimmich-dm.de/newsletter/tiedote102010.html
and it will work.
The link above, after your fix, works, showing the pix, but there are still problems in paths wrongly (IMO) created by FW.
Any idea of what I could do?
Claude
