Elizabeth, the download is a .zip archive file… TBE-CurlyBottomShadow.zip
You have to expand or “unarchive” it. Do this by double-clicking on it. It
will then create a folder called TBE-CurlyBottomShadow. Inside that will be
a Media Folder, a Site Folder, and the Freeway Pro file Pure CSS Curly
Bottom Shadow.freeway , that’s step #1.
Best,
On Tue, Oct 16, 2012 at 8:36 PM, Elizabeth email@hiddenwrote:
Thanks Ernie
But “unarchive” ?
I did point 4 but didn’t see “Pure CSS Curly Bottom Shadow”
Elizabeth
On 17/10/2012, at 10:09 AM, Ernie Simpson wrote:
I suppose that I need to add that you must be working with CSS layers, that
the box(es) you want to style need to be CSS layered html items. And your
browser has to support CSS3 box-shadows and the transform attribute, so no
IE8.
Download the Freeway Pro file and unarchive it.
Open your Freeway Pro document that you want to use the shadows.
Open the Edit Styles palette
At the bottom of the Edit Styles window, toggle the gear and choose
“Import”. Select the “Pure CSS Curly Bottom Shadow” Freeway Pro file.In the Edit Styles window you can see both your stylesheet and the
imported one. Drag the three styles (.shadowcurl - .shadowcurl:after,
shadowcurl:before - and .shadowcurl:before) from the imported stylesheet
into your stylesheettoggle the imported stylesheet closed, then delete it. Close the Edit
Styles window.In your document, click on a layered textbox and apply the .shadowcurl
style by clicking it in the Style palette. Then preview.It’s that easy.
Ernie SimpsonOn Tue, Oct 16, 2012 at 7:20 PM, Elizabeth <email@hidden
wrote:
How?
On 17/10/2012, at 9:37 AM, DeltaDave wrote:
All styled with CSS - no images were harmed during the making of this
page.D
