[Pro] Creating a Sitemap?
Can somebody walk me through the process of creating a sitemap from within FWP 6 and what the Site Mapper File Location and Site Mapper Page Option Actions are for and where they should be applied?
I looked all of this up in the latest FWP 6 documentation, but there was no mention of it anywhere, at least that I could find.
As far as the Sitemap, I was looking in the wrong manual. You’ll need to download the FWP Reference Manual. You’ll find it here: http://www.softpress.com/help/
Page 387
Okay, still at a bit of a loss as to what to do here. Any help is appreciated.
Not sure if it matters, but my page is coded as XHTML 1.0 Strict.
See this: http://www.softpress.com/kb/questions/397/Site+Mapper+Actions+suite
And this: http://www.freewaytalk.net/thread/view/79531
Excellent. Thanks Caleb.
HI,
You also may want to take a look at this thread.
http://www.freewaytalk.net/thread/view/126460#m_127580
Then you may want to look at this
http://www.softpress.com/kb/questions/144/Google+Sitemaps
John
On 11 Mar 2013, 7:17 pm, ejw wrote:
HI,
John
Interesting. So how did you create your site map?
Is this a Perch site? If so, http://docs.grabaperch.com/solutions/google-site-map/
http://xiiro.com
RSS: http://xiiro.com/musings/feed.rss
Hi
If you read the softpress kb article you will see a link to a site that creates the site map for you.
John
On 11 Mar 2013, 8:15 pm, ejw wrote:
Hi
John
Yes, I saw that. I just didn’t know if you decided to stick with a FWP created sitemap or use one of the external services.
No removed the FWP action and went the external route.
Working on the basis that the fundamental site will not change that much over the next month or so decided that the external method would be ok, if I change the site to the extent that I need an updated site map , then the external method is not that much of a challenge.
John
Have been using iGooMap for site maps - http://www.pointworks.de/software/igoomap/index.php
Marcel
Marcel
Really? Do you think that’s better than the Site Map action built into FWP?
I pulled this off Twitter, an XML site map how-to for Perch http://tinyurl.com/ashoozq. Worth reading.
http://xiiro.com
Thanks Todd. So, basically I would need at least two site maps. One for my FWP pages and one for my Perch blog. Is that correct?
No. Only one site map per site.
Is only the blog under Perch? Not the entire site?
http://xiiro.com
No, I have a blog, gallery, forms, map, and a few text pages.
